NEW! Velbus-Dali-Gateway, and more...
We haven't been hanging around the last few months and are proud to offer four new additions in the Velbus range: a Velbus DALI gateway, a universal 4-channel push button interface, a universal 1-channel input module and a magnetic gate contact.
We are proud to offer four new additions in the Velbus range: a Velbus DALI gateway, a universal 4-channel push button interface, a universal 1-channel input module and a magnetic gate contact!
One of the most striking additions is the Velbus DALI gateway (VMBDALI) . DALI (Digital Addressable Lighting Interface) is a control standard for lighting systems in professional environments such as office buildings, but it has found its way into private homes.
DALI is an easy and reliable tool which allows you to control a large number of luminaire systems.
Velbus now offers a module which makes it possible to make your Velbus installation communicate with DALI and vice-versa. Your Velbus push button, relay, sensor or other Velbus element will now also control DALI luminaires and systems.
  • integrated DALI power supply
  • DALI device settings and addressing can be configured directly in the VelbusLink software
  • 64 devices, 16 groups, 16 scenes
  • compatible with DALI and DALI-2
  • DIN width of 2 modules
Even if you are not familiar with DALI, VelbusLink will guide you through the process. You will be able to address and use your DALI devices like any other Velbus output channel.
4-Channel push button interface
Also new in the range is this 4-channel push button interface  (VMB4PB) . If the VMB8PBU push button interface is only compatible with Velbus LEDs, the VMB4PB can be used to make your Velbus system compatible with nearly all push buttons on the market, including all kinds of feedback LEDs.
You will be able to use feedback LEDs with common anode or cathode and an operating voltage up to 24V (AC or DC).
In advanced use, the VMB4PB can be set in l/O mode to allow the LED outputs to work as output channels (output current up to 10 mA @ 15 V). This way, you will be able to control third party systems through Velbus actions.
Universal 1-channel input module
This universal 1-channel input module  (VMBIN) is a new addition to the current range. You can build in this tiny module to connect a window or door contact like the new VMBCS01.
Magnetic gate contact switch
The VMBCS01 is a heavy-duty magnetic gate NC contact. It can be connected to the VMBIN.
Newsletter Update
