![Odoo • Image and Text](/web/image/5301/vmbdali.jpg)
We are proud to offer four new additions in the Velbus range: a Velbus DALI gateway, a universal 4-channel push button interface, a universal 1-channel input module and a magnetic gate contact!
One of the most striking additions is the Velbus DALI gateway (VMBDALI) . DALI (Digital Addressable Lighting Interface) is a control standard for lighting systems in professional environments such as office buildings, but it has found its way into private homes.
DALI is an easy and reliable tool which allows you to control a large number of luminaire systems.
Velbus now offers a module which makes it possible to make your Velbus installation communicate with DALI and vice-versa. Your Velbus push button, relay, sensor or other Velbus element will now also control DALI luminaires and systems.
integrated DALI power supply
DALI device settings and addressing can be configured directly in the VelbusLink software
64 devices, 16 groups, 16 scenes
compatible with DALI and DALI-2
DIN width of 2 modules
Even if you are not familiar with DALI, VelbusLink will guide you through the process. You will be able to address and use your DALI devices like any other Velbus output channel.
